full_mosey wrote:
westend wrote:
I noticed that the Go Power converter has an automatic equalization cycle. You may wish to contact Go Power and find out what the voltage is when equalizing. It may exceed the AGM's threshold.
Which AGMs specify an equalization?
Even Lifeline dropped that terminology years ago. They refer to equalization as that thing that wet folks do, Eeeeuuuhhh!
HTH;
John
I dunno, and getting into AGM conditioning is probably beyond the scope of what the OP needs to deal with right now. I only mentioned equalization as the Go Power converter he linked to has an automatic equalization cycle (once a week if the batteries haven't seen a bulk cycle). Go Power doesn't specify the voltage of the equalization cycle. If the voltage is too high, it might be bad for an AGM battery.
