KATOOM's avatar
KATOOM
Convertors and HEAT
I thought I'd share something. I always noticed that my convertor fan was running a lot when plugged in to shore power and the large storage compartment which it sits in was warm as well. Also, my battery charging voltage numbers never seemed to be what I have read they should be. For some time I thought my convertor was garbage or the wiring to and from the convertor were too small which was contributing to my inadequate battery charging issues. So I did some research and saw that its not uncommon for convertor fans to be running. But then in saying that, while recently packing up to go out for a week I had the storage compartment which houses the convertor open for days on end. Strangely even in the hot triple digit weather I noticed that the convertor fan hardly ran and my battery voltage numbers seemed strangely higher than normal. Well that got me thinking and I decided to try something. So I got an exterior vent (just like the one on my battery compartment) and drilled a 3" hole in the trailer wall and installed that vent opening directly next to the convertor. I cleaned things up and vacuumed around the area and the convertor sides and now the convertor runs as it did when the compartment door was open allowing free flowing air to pass by the unit. Obviously it seems to me that there was some overheating issues going on here and the unit didnt like running hot because my charging voltage numbers are way better and way more consistent than they have ever been. I'm curious to see how this plays out over time, but I thought I'd let anyone know who cares.
  • Glad to hear it. After hearing all the ideas others have come up with, I think I'll delve into this a little more and incorporate some more air flow venting and maybe ducting to and from the convertor.
  • Gjac's avatar
    Gjac
    Explorer III
    I checked it this morning with the door open and 60 degrees it was 13.33 volts. So that is went from 13.18 to 13.33 on a fully charged battery. I would expect it to be greater on a battery that was at 50% SOC. Sounds like you are on to something.
  • Gjac's avatar
    Gjac
    Explorer III
    I will. Right now it is at 13.18 volts with the door closed and at float and 85 degrees. I just opened the door and will check it tomorrow morning. Of course a better test would be when the battery is at 50% SOC.
  • Gjac's avatar
    Gjac
    Explorer III
    KATOOM wrote:
    And I thought I was on to something original.....
    I never thought of this. I have been sitting in 80-90 degree weather. I will try opening my compartment door to see if there is any difference in charging voltage. It is worth 5 mins of my time to see if there is any improvement.
  • I added ducting and return air grills to my converter. It drew air and discharged inside the compartment. Now it draws and discharges inside the trailer.
  • RoyB's avatar
    RoyB
    Explorer III
    I did something similar - I got one of those attic thermostats that are used to turn on a fan when the attic temperature gets to a preset temperature.
    I set it to 80 degrees for my compartment where the converter chassis is at.
    When the internal temperature get above 80 degrees it turns on a 6-inch 12VDC axial fan and exhausts the hot air out a vent in the outside trailer wall.
    I used a 12VDC FAN so that all of this will work the same if I am at a shore power site or running on batteries off the power grid.
    I used one of these TRAILER WALL VENTs that you find on most RV's where venting to the outside is required.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
