j-d
Mar 14, 2016Explorer II
Bob,
Have you discussed this before?
Or Steve,
Have you?
This sounds familiar...
If Steve's theory holds up, might be good to install a relay to power up that reversing valve. A vague signal from Switch/Thermostat would have to only trigger the coil in the relay, not the load represented by the valve's coil.
Or Steve,
Have you?
