mick2268's avatar
mick2268
Cooling problems
SO I have a Dometic Rooftop mounted AC unit, run by thermostat. Yesterday night I had it set to Auto and 72. In the middle of the night I woke up hot. I then set it to low/manual, compressor came on and ran for about 20 minutes, then compressor and fan both shut down simultaneously. I fiddled with it some and was able to get it to come on again and run for some time before it shut down again and showed and E1 error code.
in the morning I went to my dealer and they said the code meant a bad circuit board. I replaced the board and t-stat yesterday about noon. Unit came on and ran continuously until about 8:00 last night when it finally caught up with itself ( 95 here yesterday)and shut down, but would not come back on as camper heated up. Same thing! I got it to come on low/manual for about 20 minutes and it all shut down. Then I set it to high/manual and it ran fine all night, with the compressor cycling normally as needed.
Had to come into firehouse for a shift today so just set it to 74 on Auto and came to work. Figured I know if was working at all when I get back to lake in the morning.
It seems to run and cool normally, the trick is to get it to cycle properly; any thoughts or suggestions before sending it into shop???
  • Have you verified the freeze sensor is up in or on the evaporator coil?
    These are often poorly installed and they fall away and will not sense the freeze up properly.
    Access by removing interior trim.
    But as said above this sensor should just cycle the compressor.
  • We have had very high humidity this past week. I looked through my papers last night for the manual for the unit; of course its the only one not in there. Would I just go to dometic for this procedure?
  • I believe the thermostat manual explains a reset or reboot procedure.
  • John Wayne wrote:
    Do you have high humidity? if so and running on low fan speed the unit can freeze up causing it to stop until thawed out. Try running the fan at high speed.
    Running fan on high does prevent freeze issues - but my experience has been that freeze issues don't shut down both compressor/fan. My guess is the OP issue is more complex - just my 02.
  • Do you have high humidity? if so and running on low fan speed the unit can freeze up causing it to stop until thawed out. Try running the fan at high speed.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
