landyacht318
May 11, 2016Explorer
would it not be possible to Tap the turn signal circuit before it reaches the flasher unit?
My landlord's 90's era Buick lesabre has these cornering lights. Nice to have as his headlights are dim and the plastic lenses need a polishing.
I aimed my foglights to go a lot wider of an angle, and also rewired them with 10awg and a relay. This proved too much in terms of heat dissipation. Their included 18 awg wiring was apparently intended to also limit the heat generated by the bulb.
Right now the foglights are removed.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
