MEXICOWANDERER
May 11, 2016Explorer
Whoops you're not clear on the concept I guess.
Before the flasher is straight, always on, ignition signal.
"Feeding a relay coil" is self-explanatory. i do not want the side lamps pulsing as well. The lamps would need power only when turning (turn signal) Converting a pulsed signal to a continuous signal is not hard. Hiding the circuit boards inside a project box I do not have is the hard part for me. Be a shame to invest 30 dollars for an existing circuit one of the readers has seen for, say, eight dollars on eBay or whatever.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
