All_I_could_aff
May 12, 2016Explorer
Might I suggest tapping the positive circuit in between the turn signal stalk and the control box for the flasher for a positive signal to a relay which would control the actual load at the cornering lights. You could have the relay ground through a toggle switch at the dashboard so you could choose to turn the feature off if you want or leave it active.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
