MEXICOWANDERER
May 13, 2016Explorer
The circuit...
Battery - ignition Switch - flasher - turn signal - lamps.
Cars and equipment without cornering lights are all alike. It takes a special turn signal switch to power cornering lights. A double pole switch. I have to use a pulsed signal and convert it to a switched steady power source. Two relays are necessary. A diode and a large electrolytic cap for each relay. Charging time versus cap capacity for the intermittant lamp load is going to be tricky with 18 gage wire.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
