tenbear
Oct 16, 2015Explorer
I use the Battery MINDer 12117.
1. Do I leave shoreline always plugged when not using.
I leave the shoreline plugged in and turn the Converter breaker off. The CO and propane detectors are left on and I occasionally turn on a light (LED).
2. Do I turn aux battery switch on or off when using a battrrry tender.
I leave the battery switch on.
3. What size tender?
I believe the 12117 is rated at 1.3A.
4. When using tender should shorline be plugged in ?
I leave the shoreline plugged in and plug in the Battery MINDer inside the MH.
I am very happy with the Battery MINDer.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
