Big_Katuna
Jun 03, 2020Explorer II
At the risk of sounding obvious and stupid; dvms measure the voltage of what their attached to. If you connect it to the battery then you measure the battery. If you connect it to a fuse panel inside the RV then you’re measuring the volts after lots of connections and other loads. No right or wrong. It just depends on what you are trying to measure.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
