dougrainer
Nov 24, 2016Nomad
mchero wrote:
If it does indeed need the stop points reset I have the teaching pendant that Is used to reprogram the controller.I have the full wall slide and have replaced spur gears and high torque motors on those slides. I'm located in Quartzsite AZ.
Depends on which model you have. Do you have the E synch PG system? If so, the Pendant is the quickest way to program(How the OEM's do it). BUT, there is a procedure in the PG service manual for doing the programming without the Pendant. Just takes a lot longer. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
