coldchuck's avatar
coldchuck
Costco 6V battery charge rate
Hello,
I have few questions. I have searched and could not find a direct answer.
First, I list what I have:
I have a 135W panel on roof. Yes, I plan on expanding with 2 more panels some day.
It is fed 8 ga wire to combiner box on the roof.
From this combiner box, 4 ga wire is connected to a new Morningstar TriStar 60 PWM controller. It is equipped with remote battery temperature sensor.
From solar controller, 4 ga wire is connected to a pair of new 6 volt batteries from Costco.
The new Costco golf cart batteries (208 Ah each I think) are connected in series.
1 single true deep cycle 12V 80 Ah battery is also connected in parallel fashion.
All batteries cables (positive and negatives) are also 4 ga as well.
The solar controller is currently set at 14.8volt charge rate.
The question - Is this charge rate optimal for this two batteries? If not, what is the recommended voltage? Do I need equalizer schedule set?
Keep in mind due to tall profile of the battery and very tight vertical space in cabinet - I cannot easily check the water level on regular basis.
Thank you kindly for your assistance.
Chuck
  • 3_tons's avatar
    3_tons
    Explorer III
    In my view (assuming very little voltage drop via 4 AWG between controller and batts), 14.8v is a bit high as it will unnecessarily up water consumption, while 14.4v (though sufficient), will limit the EQ voltage to only 15.1v, thus 14.6v seems like a fair compromise and will still allow 15.3v in EQ mode...JMO
    Best Regards,
    3 tons
    Oops, upon a re-read I too share hmknightmc's EQ voltage concern...This had not occurred to me since I do a system disconnect before equalizing...
  • 14.8 for how long in what conditions?
    While in use 14.8 for 0 to 60 minutes should be fine. Longer and you will be burning water.
    Storage 14.8 for 0 to 5 minutes is plenty. Actually 14.2 daily should be fine and reduce water use.
  • coldchuck wrote:
    The solar controller is currently set at 14.8volt charge rate. The question - Is this charge rate optimal for this two batteries? If not, what is the recommended voltage? Do I need equalizer schedule set?
    Have you checked the myriad charge algorithms online?
  • You need to look up the manufactures recommended charge profile from their website but 14.8 volts with temperature compensation should work just fine for those batteries. Personally I would set equilize to 15 volts ( not higher to protect RV electronics) every 30 days and lose the bady 12 volt battery.
    Opinions will vary
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
