landyacht318
Oct 16, 2015Explorer
BFL13 reports the 15.7v equalization mode on the B&D40 works well, but one might have to do it more than once.
I know lead acid batteries do not have a memory, but it certainly seems like those that have been sitting and then top charged, respond better to a mid level of depletion, followed then by a full charge.
The Screwy 31 taught me not to screw around with 15.xx for equalizing. There was one instance where what couldn't be done in 3 to 4 hours at 15.7v, took 20 minutes when bumped upto 16v.
Later on I only backed off from 16v if it took more than 6.2 amps to get the 130 AH battery up there after a full absorption charge cycle, or amps started rising without a voltage increase.
Nothing quite like spinning that desired end voltage dial and some thick copper between source and battery.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
