Fishinghat
Jul 11, 2013Explorer II
If your brother doesn't use the humidifier on his CPAP, your two batteries should power it for several days without recharging. The Honda generator will take several hours to charge up the two batteries, unless you use two battery chargers, one for each battery. The problem with recharging batteries is it takes quite a bit of time to top them off and you really want to do that if possible. As for your other electrical demands, I don't know.
I use a CPAP in our coach, and don't have any problems dry camping, but I have four deep cycle batteries that also power up everything in the coach.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
