bgrasspkr
Jul 12, 2013Explorer
Searching, and wbbeasly,
From your posts, seems you are running units 12vdc directly from your bats, WITHOUT an inverter. I do not have that option. Thus, my original question on inverter efficiency. Looking back, while people have given, a lot of info, none have seemed to know how efficient these inverters are.
Bottom line: Run a CPAP without heat and humidity direct from battery, no problem w/ 2 or 3 nights on a group 24 battery, according to actual users who have posted.
I, will be using a cheap Radio Shack 300 W inverter. How much MORE( than the approx 2 amp rating) current will this draw.
I have 2 Group 27's paralleled. If I could go direct w/o inverter I could use it for a week! Are these inverters really that inefficient so as to double or even triple the current draw. Doesn't make sense
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
