pianotuna
Jul 12, 2013Nomad III
Hi bgrass,
You need to think in "watts". 2 amps X 120 volts = 240 watts.
240 watts divided by 12 volts = 20 amps.
Those numbers assume 100% efficiency. You will never get that. 90% is considered good, so draw may be 22 to 23 amps @ 12 volts.
It is entirely possible that the 2 amps is a maximum draw and that the CPAP uses less. The only way to tell is to plug it into a watt meter. My favorite is a kill-a-watt
watt meter
watt meter
bgrasspkr wrote:
I, will be using a cheap Radio Shack 300 W inverter. How much MORE( than the approx 2 amp rating) current will this draw.
I have 2 Group 27's paralleled. If I could go direct w/o inverter I could use it for a week! Are these inverters really that inefficient so as to double or even triple the current draw. Doesn't make sense
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
