VinnyP wrote:
Need a little clarification. The ball valve in my Dometic 310 toilet has somehow developed a crack and no longer holds water. I called Dometic and was told the ball cannot be replaced, and that the whole toilet must be replaced. I am having trouble believing that. Can anyone shed a little light here?
Thanks
The ball can not be replaced... Since when.
The link below is NOT a recommendation. just the part number
You can likely find it for less.. I googled Dometic ball valve
I HAVE INSTALLED ONE OF THESE so I know they exist.
The part you need at boat and RV accessoriesALso are you sure it is cracked? THe seal often needs cleaning on these turkeys.
