dougrainer
Aug 30, 2020Nomad
GDS-3950BH wrote:Lynnmor wrote:bedpan wrote:
For those interested here are some documents from Lippert that I believe apply to the repair needed. Saying that as I was looking for links to post for them they appear dated..
Heartland Document - Lippert Repair
and here is one from the NHTSA but the document date is 2009
https://static.nhtsa.gov/odi/rcl/2011/RCRIT-11V486-1111.pdf
That is basically what is needed. The break next to the bottom flange will need some additional attention. The cross pieces do the same job as the X-Factor. I made my own and bolted them in to allow removal for service above.
And there you have it......Lippert even has SOP's and assigned number parts in place. Sort of makes one think why the reinforcement plate and tubes are not used when fabbing their junk to begin with.
They're simply gambling on folks not using the rig enough during the warranty period for the issues to crop up.
Seems people want to blame Lippert. WRONG Company. It is Heartland. LCI just builds the frames to the SPECS that the RV Maker engineers supply. So, LCI gets the gauge metal(Heartland specs) and installs the crossmembers and hangers where the HEARTLAND engineers state to install. When LCI goes out in the field to repair frames, they Charge Back the cost to the RV Maker(Heartland). Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
