liveneasy
Oct 11, 2013Explorer
I'm going to assume your talking about the plastic part that's an integral part of the door that the hinge pin sits in.. as most hinge brackets are metal. Mine cracked several years ago and I've been unable to locate a reasonably priced replacement door/door frame. My solution was to rebuild the hinge using JB Weld. Lots of shaping, sanding and drilling done with a dremel but it looks pretty good and has held up for 5 years now. I'm full-time so that's a lot of use.
If you don't want to go that route you might try locating a replacement door at some of the RV salvage yards.
