SidecarFlip
Apr 02, 2019Explorer III
shastagary wrote:
if i want to make sure a crimp connection will last i crimp the lug on and then solder the lug.
some have a hole just in front the crimp part the ones that do not i drill a small hole in front of the crimp and heat the lug with a small butane torch wile feeding solder into the hole till it is full.
i have cables i made back in the 80's that are still in use today that work and look as good as the day i made them.
Exactly. I use welding cable (available by the foot at any LWS retail store), Tweco solid copper connectors and I remove enough insulation to tin the end, insert the end in the Tweco connector and then solder it in. I like to use welding cable because it will be solid conductor grade copper stranded wire and the insulation jacket it thicker neoprene.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
