S_DavisExplorerApr 02, 2019Crimp connectionsFor those of you that make your own cables do you use anything on the wire before you crimp?
BipeflierExplorerApr 02, 2019Hubbell Joint CompoundIf it is good enough for the electrical utilities, it is good enough for me.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
Related ContentQuick connect exterior shower hose doesn't connect.Nautilus P1 has leaking connections12V Electrical wiring - wire nuts vs crimp connectionscrimping battery lugCrimp, Solder, Crush
