3_tons
Apr 02, 2019Explorer III
navigator2346 wrote:3 tons wrote:
Before I crimped my 0004 welding cable copper lugs, I inserted a small coil of silver solder in each lug...After crimping I then heated the lugs with a torch, my goal was to have as low connector resistance as practical.. FWIW, silver is a better cinductor than gold...
3 tons
Problem with soldering lugs is that it can make the soldered joint brittle. With coach vibration, the wiring can break. That is the reason you don't find soldered connections in aircraft wiring.
Never tried to fly my truck camper as of yet, but I’ll keep it in mind!!
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
