GordonThree
Apr 03, 2019Explorer
MEXICOWANDERER wrote:
Problem with soldering lugs is that it can make the soldered joint brittle. With coach vibration, the wiring can break. That is the reason you don't find soldered connections in aircraft wiring.
HORSE
PUCKY
I've held an FAA PMA license for electrical systems and a second license for aircraft starter motor and alternator rebuilding for 29 years.
It's good to have you back on the forums :)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
