MEXICOWANDERER
Apr 04, 2019Explorer
I'll add this as a tip
There are times when added strain relief is desired for -any- electrical termination.
Use 3-1 heat shrink tubing over the joint.
Then slip on a 2nd piece of tubing over the first shrunken tubing but make it a bit shorter in length.
If it took several hundred 90 degree flexes to fatigue soldered or bare wire, you'll spend thousands of flexes before you give up trying to break a doubled application of heat shrink tubing. It simply will not break. Unlined heat shrink tubing is almost worthless.
Worried about the inherent strength of the wire itself? Select -Cross Link- insulated wire. As a bonus Cross Link Wire withstands higher temperature. As a negative it is difficult to find tinned Cross Link wire. DLO wire is much tougher but available solely in black.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
