MrWizard
Sep 20, 2017Moderator
i like everything EXCEPT fridge on solar during the day
that 300+ watts is a lot of drain
you might find you don't always have that much 'excess'
imo better off with the fridge on LP and any excess? will be put to use when you use the MW, both while cooking to reduce battery drain, then after cooking to replace used ampHrs
if you want to use elect for fridge, replace the fridge, with either a residential fridge or a DC compressor fridge with a dan Foss style compressor
either one will use less electric energy (amp hrs) than the RV fridge,
1/3 the power or even less
i'm sure PianoTuna will be along and elaborate on power use of an RV fridge on solar and batteries
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
