2oldman
Sep 21, 2017Explorer II
time2roll wrote:x2.
Lithium is going to seem like a leap. However half your solar is going to be wasted on absorption time with the amps tapering off to nothing with the AGMs....lithium will absorb all the solar you can produce right up to the point of full.
Also as you get into the 1 kW solar zone consider going 24 volts on the main battery and inverter.
Li's are great, but will dent your wallet something fierce. If you can handle the $1000/battery you won't look back. Zero maintenance and much less weight than lead batteries. And way less voltage drop on high-draw appliances.
24 volts or higher is a great idea. You don't need cables the size of your thumb. I'm running 48vdc. Small converter for the coach's 12v supply.
Running higher voltage solar is what I also recommend. Again, smaller wire size and more efficiency. Of course you'll need a controller to handle the input voltage.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
