phemens
Sep 22, 2017Explorer
Thanks for the opinions, but I didn’t state the purpose of why I want to do it (‘tinker’ with solar, be eco-friendly, etc) and i’m not clear on what difference that makes, or how much work it might be. I’m not a newcomer to solar, been using it for over 8 years. You are inferring a lot of things from stuff I didn’t say, like wanting to not cook with LP, or not run the fridge at all on LP, or that I don’t know how to perk coffee over the campfire ;)
Let’s assume I know what i’m doing (like not planning to set up 1000 watts of solar at 12v) and i’ll repeat the last question asked: has anyone observed any appreciable benefit in using AGM over FLA for short duration high load use with inverter? This might be the difference between 4 AGMs for me or 6 FLAs. Thanks! Mr. Wizard, your use case seems much in line with what I am doing - If you don’t mind me asking, how many AGMs are you set up with for what total usable amps and what inverter size?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
