BFL13
Oct 07, 2017Explorer II
The charging specs on those is 14.7v bulk and absorb with 13.6 float. PD9200s can't do that except perhaps the ones modified by Randy at bestconverters.
http://www.fullriverbattery.com/product/batteries/DC215-12
You will want a high amp charger to keep your gen time down doing 50-90s. The high amp PDs are not PF corrected so they take a lot of VA.
You would do much better IMO with one of these, which has high amps, PF correction, and best of all--adjustable voltage. eg if it is 35F out, your 14.7 will really be 15.26 ish temp comp, so you can set that. You can't do that with even a 14.8v modified PD.
http://www.boatandrvaccessories.com/products/powermax-pmbc-100adj-charger
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
