wilanddij
Aug 01, 2013Explorer
Working w/o toad - not working w/toad = problem in toad, or cable to toad. I'd make sure I was passing a solid ground from toad to rv. By make sure, I mean add a ground wire, don't depend on passing ground thru the towbar.
Also, you may want to pull the cable connectors apart to check for loose wires inside. The blue coiled cables have small set screws holding each wire in place, and if they become loose all kinds of strange problems happen, but only when you tow.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
