ktmrfs
Jan 24, 2021Explorer III
BobsYourUncle wrote:ktmrfs wrote:
If the truck uses 9004/9005 bulbs, IMHO the best update is to replace the 9004/9005 with 9011/9012 HIR bulbs. Same watts, higher lumen output, about the same life as a std 9004/9005 but more expensive. you will need to slightly modify the 9011/9012 plastic base to let it fit in the 9004/9005 shell.
Mine is actually the 9005 / 9006 bulbs. They have a 90 degree angle to the connector, not straight out as the 9004
I had brain fade, the 9011/12 replace the 9005/6
the 9011/12 have the right angle connector, and when toshiba quite making the HIR 9011/12 the other companies went with the traditional 9005/6 glass shape rather than the bulb at the end like toshiba did.
