otrfun
Aug 31, 2021Explorer II
For those folks with 2010-2018 Ram trucks. We installed a set of 9005 high beam/H11 low beam Sealight LED's on our 2016 Ram 3500 with standard OEM reflector headlight assemblies. As long as you don't mind modifying the mounting ring on the 9005 high beams to get them to mount at 9 & 3---it's a simple plug and play installation with no load resistor or ECM programming necessary. Retained the original OEM halogen beam pattern after some minor adjustment. The Sealights are a very bright white---very little to no blue cast. They significantly improved our visibility at night---at least double the brightness/lumens vs. the OEM halogen bulbs. Have yet to have anybody flash us.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
