RedRollingRoadb's avatar
Sep 22, 2014
Cummins Filter Recall
Cummins Filtration is recalling more than 63,000 fuel filters due to the possibility they could fail. The filters were distributed in both the aftermarket and on certain Cummins engines manufactured earlier this year.
The recall affects the Fleetguard UFF-XT fuel filters, part number FF63009,
Approximately 42,000 of these filters were distributed as replacement filters in the aftermarket. About 21,600 were installed in Cummins ISB engines built between April 28 and July 9 and ISL engines built from April 30 to July 8.
http://www.truckinginfo.com/news/story/2014/09/more-than-63-000-fleetguard-fuel-filters-recalled.aspx
  • JRS & B wrote:
    Great. I just dropped off my Ram Diesel at the dealer, and told them to change the fuel filter while it was in for other work. I hope Dodge dealers don't use after market filters.
    You'd better hop he does use an after market filter. Apparently theu are not affected.
  • From what I can tell this filter is not used in Dodge Ram LDT's.
  • Great. I just dropped off my Ram Diesel at the dealer, and told them to change the fuel filter while it was in for other work. I hope Dodge dealers don't use after market filters.
  • "The recall affects the Fleetguard UFF-XT fuel filters, part number FF63009, According to Cummins, the bond that attaches the filter shell to the filter nut plate may fail. If this occurs, the shell may separate from the fuel filter nut plate, causing the engine to stall without warning and without the ability to restart the engine until the fuel filter is replaced."
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
