DougGreen's avatar
DougGreen
Cummins loses power
We have a 1999 Holiday Rambler with a 5.9 Cummins motor. We are having trouble with it losing power. This happens on flat ground and at any speed. The engine light will come on and we cannot go faster than 15-20 mph. It does not smoke, jerk or otherwise run badly.
After a minute or so, the light goes off and the power comes back. this happens every 15 minor so. When this happens, the Turbo Boost is at 0. We took it to a shop and they could not figure out how to get the codes to see what the problem was. We have changed the fuel filters already and it made no difference.
  • possible loss of fuel pressure, or high pressure injector pump on the way out.
  • I had a turbo sensor on my Ram go out that had th same symptoms, except it wasn't intermittent. When to a Cummins truck repair shop and it took about 4 hours to isolate and diagnose.
  • we had that problem, 4 shops later found a 3rd fuel filter inside the door where the coach air conditioner compressor,dryer is located
  • This sounds like an electrical or computer problem. Zero boost for a period of time and then regaining the boost necessary to travel at speed doesn't sound like a hole in the turbo charged air system. It doesn't sound like a fuel filter either. If the fuel filter were plugged, it would remain plugged.
    If your Cummin's is like mine and it sounds like it is, the primary fuel filter could be working intermittently. Even when it quits working the secondary will suck fuel through it but not at a rate necessary to run at speed.
    Like other, I think your going to have to resort to having someone pull codes.
  • X2 on fuel filter. With a Cummins that is the first place to look.
  • The standard first fix for loosing power is change the fuel filters. My take is that the engine is de rateing due to generating a fault. Change the filters and if that does not fix the problem find someone who can read the engine codes fast.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
