benb21601 wrote:
After countless hours of searching, I could not find the the oil specs recommended for the rv generator. I finally broke down and went to my local Cummins center, and bought the factory Onamax 15w-40. I say broke down, but honestly at $5.50/quart, i cant think of a reason to use anything else. But for anyone else looking for the specs, here they are:
API Certifications - CJ-4, CI-4, CI-4 PLUS, CH-4, CG-4, OF-4, OF/SL
As I said, 15w-40 is what they said to use, which is part #326-5336 for a quart. A quick search of my standard go-to Mobil 1, showed it did not meet all the same specs.
FYI- hope this helps.
FWIW, the specs that you list are diesel oil specs. Mobil 1 is for gas engines.
