wopachop
Aug 22, 2020Explorer
There is also a start toggle on the genny itself. You can use that and cross your fingers if it happens again while camping.
Could be a bad switch inside the trailer. Loose wires to that switch. Loose connection on back of switch.
Remove that panel and check out the work. I have a stealth and constantly amazed at how bad the construction is. The wiring is really bad on my particular 2013. Hopefully that crew is gone by the time they made yours!!!
