MrWizard
Aug 22, 2020Moderator
These are pretty small starters
The gear engagement is via spin out against a weak spring
I suspect bad winding or a sticky brush
When the brushes are resting on the bad spot
The you get the current drain on the batteries without the starter turning
I suggest replacing the starter
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
