placergold
Aug 23, 2020Explorer
wopachop Have tried the toggle outside at the generator as well, nothing.
"Could be a bad switch inside the trailer. Loose wires to that switch. Loose connection on back of switch". I will have them "Remove that panel and check out the work". I think that is a good idea!
I bought a new F37SP Sierra from Forest River back in 06" (I think) did the factory tour back then too. Never had any generator or electrical issues with that rig, and the construction/workmanship was pretty good in my opinion.
Unfortunately, I think the same crew was still there when this one was built too, the construction on this 2018 Stealth is terrible!
MrWizard I will have to take the rig to a "authorized" Cummins Onan repair shop in another town to have the starter even looked at. Glad I made a backup appointment with them for next month, just in case! With so few hours in mild climate, and close to sea level most of the time, I would not expect a starter or related component issue...... Hopefully this issue will get resolved next week at the local shop its in now.
I keep going back to why the Go Power Solar Inverter display, flips out, when a failed starting attempt occurs. In their user's manual they call it a "voltage overload". And yes, I've called them in Canada twice over this issue, to no avail.
Thank you both for your input!
