MrWizard
May 14, 2023Moderator
"There is no vacuum being pulled into the bottom of the mixer when the engine is cranking -- required for the LP regulator diaphragm to open the inlet valve."
Can you attach a manual Vacuum pump to that inlet and use it to operate the regulator diaphragm, maybe get lp to engine
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
