jaycocreek
Mar 19, 2021Explorer II
time2roll wrote:
"Fault Alarm 3" does not have any reference?
Ummm i can't find it and it must be over the sellers head for him to send it to the manufacturer..My wild guess is a bad BMS..It won't reset to factory settings either,the parameters all went to the number 2 when I hit the factory reset..He was going to send me the parameters but I don't think the app will let me change anything since it won't even let me set the battery type..
From everything I read and asked ,the 14.6 volts nor the Noco charger set on lithium should not be a problem..The BMS is supposed to step in if any issues come up,like for cold weather charging,as an example..
Thanks
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
