BFL13
Mar 20, 2021Explorer II
" But then I only have over 1,600 cycles of 35-45% DODs drawing 150-200a load at any SOC in the past 5 year of full timing."
Noted. Also noted is that 200 amps on a 500AH bank is 0.4C rate, and that 35% DOD and to avoid the upper knee, your range is about 35-95 so 60% of rated AH. You also use AH counting.
Don't tell anybody here that you are not using 100% of the rated AH or you will be tarred and feathered
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
