BFL13
Mar 20, 2021Explorer II
The BMS does not control charging, you do. As Itinerant1 has warned several times, the BMS is the last ditch stand when all else has failed.
You need a monitor so you can do your part, and that monitor has to be zeroed often enough to stay accurate.
I am unclear if that Victron automatic "syncing" (what they call zeroing) will do it right. Could do if the settings are chosen properly?
I am suspicious of that because I don't like how my Trimetric auto reset works as designed. I have that disabled and do manual AH counter resets when I decide to.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
