time2roll
Mar 20, 2021Nomad
LFP is different from FLA to know it is full. Once LFP gets into the upper shoulder for voltage it is full. It just is every single time. This is different from FLA where you are trying to remove those sulphur ions from the lead and you are never quite certain if you have them all. So you push and push and push scrubbing harder and harder until you give up and call it full. A very different chemical process.
LFP is like filling a tank and when the voltage runs over it is full. Charging FLA is like draining the tank where you keep shaking it and shaking it to get every drop of sulphur out. Maybe even go in and wipe it with some equalization voltage.
Different paradigm, no need to apply the same rules.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
