BFL13
Mar 20, 2021Explorer II
The charging profile in the graph here -scroll down to "charging LFP"
does not show that. The voltage curve upper knee is earlier and then holds for Vabs. I am unclear when the balancing act occurs on this profile.
https://www.solacity.com/how-to-keep-lifepo4-lithium-ion-batteries-happy/
Even if the "full" is not an issue so zeroing the AH counter is not needed, you still use AH for knowing where you are for SOC while operating. Besides the voltage being too flat for that, you have loaded voltages.
If the Smart BMS uses voltage per SOC, and you allow that it can use the flat voltage for its SOC (Trillium's only gives an approx SOC "window" or bandwidth idea for its SOC display), what about loaded voltages?
You can look at the battery voltage while a load is running and see it does not represent SOC, but the AH counter still does. Does the Smart BMS use show an AH count?
My question has not been answered-- how does the Smart BMS know what the SOC is while the inverter is running the battery down and the voltage is the loaded voltage? How do you know you are as low as you dare to go towards the lower knee?
Itinerant1 says he plays it safe and stays well above the knee. He foregoes using the extra AH he could use by going lower. He can, because he has 500AH to play with.
If you bought your single LFP, believing the ads that say you can use 100% of its capacity, and you want to get your money's worth doing that, but then find out about the lower knee so you can't/shouldn't, then you will want to get as close to the knee as you can get away with. Now you need a way to tell when you are as low as you can go and get away with it. (unless you know you have a 120AH rated at 100 so your 0 is really 20 DOD--but what about the voltage/real SOC? Is the 10v for 20 DOD and not 0 like it says?)
Say you are watching TV at 10 amps for a few hours on inverter, from your 100AH LFP. 3 hours is 30AH which is a lot from 100. If your knee is at 10% DOD, then you need to start at 40% DOD to get your three yours in. If the BMS is reading loaded voltage from that 10 amp draw (not so much drop with LFP, which helps some) it will call 10% too soon before your 3 hour movie is over. If you go past the knee at all, voltage will crash so you need to stop quickly before the BMS shuts down. You really need accuracy as with the AH counter when skating on thin ice like that, and the loaded voltage while the inverter is running the TV isn't going to do it AFAIK.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
