StirCrazy
Mar 21, 2021Moderator
BFL13 wrote:
The BMS does not control charging, you do. As Itinerant1 has warned several times, the BMS is the last ditch stand when all else has failed.
actualy some do, well they all do in a way, when it hits the cut off it shuts off the charging, when it drops a spicific percentage it starts the charging again... if that isnt controling please tell me what is. all a LFP needs is a constant voltage to charge so to controle it you turn it off and on.. hmm seems like what I just wrote.
better quality BMS will let you talyor the cutoffs and cut ins to what you want to allow finer control.
Steve
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
