StirCrazy
Mar 22, 2021Moderator
time2roll wrote:
I don't think you want the BMS isolating the battery to control charging in an RV. Generally the battery should be connected and operating continuously. The high voltage cut off is to protect the battery, not control poorly designed charging.
you might be right now that I think about it. would depend if it only isolates the charging or if it totaly disconects the battery. if a high voltage or current in charging causes the BMS to totaly disconect the battery that is not a good way to do it haha..
I always say if your going to spend that much on batterys get the proper converter so a 14.6V constant voltage converter in this case.
Steve
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
