BFL13
Mar 22, 2021Explorer II
Choice is what you get with an adjustable voltage. LFP says no temp comp because 14.6 is 15 when it is cold out. With adj voltage you can set the voltage with some temp comp when it is cold out and keep it below 14.6.
If you charge at 14.1 at 25C/77F, then in the cold you could make that higher so it is really 14.1 and not equivalent to 13.x
That is why I like the adj voltage PowerMax LK and not the PD with CW. With the PD you only get one voltage--minus any voltage drop. good point by 3 tons on that- (unblocked ) for what voltage the battery sees.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
