StirCrazy
Mar 27, 2021Moderator
pianotuna wrote:
Steve,
My concerns are for the "drop in" folks who don't realize that LiFePo4 require strict parameters to be met.
Your charging example is one such number. Alternators may (or may not) fail, due to exceeding their duty cycle. My understanding is that a 180 amp alternator (larger than I have) has a continuous rating of about 60 amps. Li are "greedy" and can charge at 1 C. Most folks would want at least 200 amp-hours of storage.
Any battery can be made to work well in an RV and if the end user is knowledgeable LiFePo4 can be marvelous.
I think that anyone following this thread is going to be a happy owner. But for others who don't have inquiring minds.....not so much.
I dont thing the requirments are any more strict than normal batteries or SiO2. maybe even less strict in some ways. normal batteries you need a three stage charger with desulphacation, and you need to watch water levels, make sure it is fully charged below a spicific temp or it will freeze, dont let it get to hot, and only use 50% .. miss any one of these and you can kill your batteries in short hand
SiO2 has some of the same but more strict in some, dont charge more than 25amps (average camper has a 45 to 75 amp charger), dont use to hot, dont use to cold (although that one is there shining star), dont run below 20% SOC, I am not sure of there charging profile requirments as frankly it is hard to find real info about them asside from sales sheets.
Li dont charge or discharge to cold (very managable targest for most) only need a single voltage charge requirment, dont run to hot (very close to SIO2 upper limit depending where you look its the same give to rake 5 degrees.) no levels to check, no worry about vibration no worry about running it down to 0% SOC as thats what its cycles are based off.
so in a way there are two that are , not nessasarly more strict but less optamal for a small group of people but he rest would more than make up for them. the altanator example the only way some one would be able to do that is to bypass there whole system with new wires than are not fused, and eeven then on the newer batteries I think the smart altanatore would shut down (but Im not sure) at anyrate the charge profile coming off a altanatore in a car isnt what we want for any battery thans why I have it disconected on both my 5th wheel and camper. I am going to actavate it again but with a little 20 or 40 amp dc to dc so I can controle the charge profile. my 6V GC batteries in my 5th wheels didn't last 16 years and counting for no reason. you have to treat any battery tyoe right and they will treat you right.
Steve
Steve
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
