FWC
Mar 28, 2021Explorer
The point with LiFePO4 is that you can pull 100% of their rated capacity out of them around 3000 times, probably more under optimal conditions (room temp, low C rate). Unless you need more than 3000 cycles, there is really no need to stop the discharge at 80%. There is plenty of independent research to verify this, that I have posted before.
A manufacturer may choose to de-rate (ie specify a lower capacity than what is available) their battery for multiple reasons - to prevent warranty issues for abused batteries, to account for manufacturing variability, to broaden the acceptable temperature range etc. All that really matters is that the battery can meet the manufacturers spec.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
