FWC
Mar 28, 2021Explorer
Assuming you have the model with the accessible cells, you could consider switching the Daly BMS for a different and more reliable bluetooth BMS:
Overkill BMS
Also available for less straight from the manufacturer:
LLT Power
The nice thing is you get both control of the BMS functions (balancing, low temp cutoff etc) as well as battery capacity monitoring, so you don't really need the BMV.
Overkill BMS
LLT Power
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
