FWC
Apr 03, 2021Explorer
Unfortunately you will never really know if the cell level BMS protections are working without access to each cell.
You could test the pack level protections by running the pack down below 10.0V. The pack should shutdown.
jaycocreek wrote:
you do have another option here, you could buy a victron bluetooth smartshunt and be able to monitor everything thst will help you determin if your BMS is working.
I have searched the net for a couple days trying to find something that tells you how to tell if your BMS is working properly in a sealed battery..Can't find anything..
So how can I tell if my BMS is working properly with the smart shunt?
After the crazy readings I'm certainly an curious.....
